90toydolphin Posted March 22, 2012 Share Posted March 22, 2012 i posted this on the forum page but didn't show up under new topics, sorry if becomes a duplicate. i have a 1989 and want to replace the radio. when searching for how to remove the radio i found that all the bottom half of the dash needs to come off and the heat/air controls. is there an easier way or do i just start pulling it apart and hope i can find all the clips that break? any help would be helpful. Quote Link to comment Share on other sites More sharing options...
Galvanized Knight Posted March 22, 2012 Share Posted March 22, 2012 i posted this on the forum page but didn't show up under new topics, sorry if becomes a duplicate. i have a 1989 and want to replace the radio. when searching for how to remove the radio i found that all the bottom half of the dash needs to come off and the heat/air controls. is there an easier way or do i just start pulling it apart and hope i can find all the clips that break? any help would be helpful. A factory service manual for the 1989 pickup should have all the details. I installed a few stereos and you are right to worry, that old plastic snaps easily. GK Quote Link to comment Share on other sites More sharing options...
rvman Posted June 5, 2012 Share Posted June 5, 2012 i did it and you do not have to that much apart. Quote Link to comment Share on other sites More sharing options...
90toydolphin Posted June 6, 2012 Author Share Posted June 6, 2012 i got it done, was surprised that the old plastic didn't fall apart, didn't have to replace any connectors. my biggest problem was that the original had been changed out prior and some changes had already been made so one was supposed to fit without hassle didn't fit real well without some tweaking, cutting, grinding, reconnecting wires and holding my mouth just right and crossing my fingers. so needless to say took a little longer than i hoped but not too bad. with a little plumbers tape and few extra bolts and nuts from my collection it got done and looks factory. Quote Link to comment Share on other sites More sharing options...
