Stevo Posted February 21, 2013 Share Posted February 21, 2013 Hey thanks! Could you find out the following when you get a chance please... - How thick is the plywood that was used for the headliner and the walls? - Were the walls done the same way as the ceiling headliner (vinyl wrapped around plywood)? - What are the dimensions of the wood backing thats glued to the walls and the ceiling that you screwed the vinyl clad panels into? - When you glassed in the opening where the front over-cab window was, did you use pre-made fiberglass sheets? If so, where did you buy those sheets? Thanks again. Quote Link to comment Share on other sites More sharing options...
