gene jo Posted January 15, 2012 Share Posted January 15, 2012 Does anyone have the torque specs for attaching the front rotors to the back of the large front hubs on my 92 Dolphin? Also the spec for attaching the caliper and the caliper brace's larger bolts? Can't seem to find them anywhere. Thanks Quote Link to comment Share on other sites More sharing options...
Derek up North Posted January 15, 2012 Share Posted January 15, 2012 If I wasn't on dial-up, I'd look before replying, but have you checked in the FSM? http://personal.utul...buchanan/93fsm/ Quote Link to comment Share on other sites More sharing options...
gene jo Posted January 15, 2012 Author Share Posted January 15, 2012 If I wasn't on dial-up, I'd look before replying, but have you checked in the FSM? http://personal.utul...buchanan/93fsm/ Thanks a lot, I found it. It was listed as a 4-wheel drive brake though (Front Brake--4WD (S12 + 12 Type Disc) not sure why it's under there as it certainly isn't 4-wheel drive. Thanks again. Gene Quote Link to comment Share on other sites More sharing options...
Derek up North Posted January 16, 2012 Share Posted January 16, 2012 Well kudos to you for having persisted long enough to find it, if indeed that's what you're looking for. Quote Link to comment Share on other sites More sharing options...
Maineah Posted January 16, 2012 Share Posted January 16, 2012 Good find, also tighten them like you would wheel bolts tighten one skip to the other side etc just snug then torque them. Quote Link to comment Share on other sites More sharing options...
