waiter Posted December 3, 2011 Share Posted December 3, 2011 I had a very minor leak at the top of the kitchen window. if it rained real hard, I would get a small puddle on the kitchen counter behind the sink. ** Sorry, no photos, the Wife had the camera ** Thinking it may be coming down inside the wall from the roof, Last week, I carefully resealed the roof above the window. When I did the roof, I didn't see anything that I suspected was causing the puddle. (Scratching head) Next rain, same problem. I looked at the exterior of the window, I didn't see anything obvious and. The only way to tell for sure is to pull the window out.. :unsure: Today I pulled the window, and I found the problem. The window had a nice bead of something (I think polyurethane, but may have been silicon) from the factory, looked very good, looked like it should have sealed. When I got the window out, I found that the window had a foam seal around the inside of the frame, and this seal was pinched and not positioned very good. and it was allowing a small opening for an occasional water drop to sneak in on the very edge where the sealant bead had separated from the frame. The window original had a foam seal. kind of like that stuff you buy at the big box store, maybe 1/2 square with adhesive strip on one side. First, I don't like the foam as a water seal, so I cleaned as best I could, I used a wire brush to get the foam off the frame, then I used lacquer thinner to scrub and clean most of the foam adhesive off the frame. The exterior opening cleaned very easily, and I wiped everything with lacquer thinner. I had some 3/8 urethane bead left over from a Ford window, so I ran this around the inside of the window fram, not as a seal (although it might help) but more to position the window in the opening. I used blue painters tape on the exterior opening and also the exterior of the frame so when I ran the caulk, it would clean up easier. I got some urethane caulk (King Caulk or something like that) adhesive/sealant and squirted a big bead all the way around the window frame. I then ran a nice big bead all the way around the window opening. I pressed the window back in the opening, checked that I was getting sealant squirming out of everywhere, and tighten the internal frame. I then used a small plastic squeegee to clean up the the sealant where it squirted out, so I have a nice bead all the way around the window. I then removed the blue tape. Its supposed to rain tomorrow, we'll see if this solved the drip. ALSO - I don't like the way the windows were originally seated using that foam, so next spring, I'll reseat the other windows. John Mc 88 Dolphin Quote Link to comment Share on other sites More sharing options...
waiter Posted December 4, 2011 Author Share Posted December 4, 2011 Today - Heavy, steady rain. :thumbdown: Kitchen Window, NO LEAKS :ThumbUp: I'll redo the other windows next spring. John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
