Wilson_ Posted September 24, 2011 Share Posted September 24, 2011 Here are a few links and info I found Bracket Kit Info from YotaTech The stock alternator light function on the dashboard will be retained as will the sense wire to preventing voltage drop in the electrical system. The biggest gain is stock output, the OEM denso will only give you around 40 amps idle. The GM alt will give you around 90-100 amps idle, and full output around 1500rpm. Quote Link to comment Share on other sites More sharing options...
Bryan B Posted October 3, 2011 Share Posted October 3, 2011 Here are a few links and info I found Bracket Kit Info from YotaTech or try a toyota or honda Alt. upgrade here http://home.earthlin...galt.htm#hongen Quote Link to comment Share on other sites More sharing options...
