grc Posted May 6, 2011 Share Posted May 6, 2011 I like to share this project idea. I want to take a Toyota Tacoma access cap, remove the truck bed and build a solid wall pop top camper as shown in the computer rendering pictures below. Note: the truck used in this picture is a Ford ranger because I could not find a good Toyota model in Google sketch up, but you get the idea. The interior picture has the top walls removed for better viewing. Some Features and specifications: · Queen size bed · 6' 5" Extended Ceiling height · Air-conditioning · 1.7cu/ft 12vdc/120vac Refrigerator · 2 burner Propane Stove · Stainless Steel Sink · 2x Large Roof Vents · 12v interior lighting · Hardwood Interior · Foamed in-place Insulation · Deep Cycle Battery · Closet with drawers · Mini Blinds · Portable Toilet · 12 Gallon Water Tank · 6 Gallon Black water Tank · SHURFLO Electric Water Pump · 2x 120V outlets · 12v/120v Power Converter/Battery Charger · Fire extinguisher Quote Link to comment Share on other sites More sharing options...
clay Posted May 14, 2011 Share Posted May 14, 2011 ever check out expedition portal? lots of DIY builds there like your plan. you should build it. Quote Link to comment Share on other sites More sharing options...
