bokwus Posted November 30, 2006 Share Posted November 30, 2006 How common is the five speed transmission and assume that the fifth gear is an overdrive? How easy is it to replace or repair my odometer? Thanks - John Quote Link to comment Share on other sites More sharing options...
Dirk Posted December 21, 2006 Share Posted December 21, 2006 <br />How common is the five speed transmission and assume that the fifth gear is an overdrive? How easy is it to replace or repair my odometer?<br /><br />Thanks - John<br /><br /><br /><br />hi John, I'm no expert, but from what I've seen, the 5 sp manual transmissions are fairly common. Here's two good links for more research: http://www.4x4wire.com/toyota/faq/ http://www.4x4wire.com/toyota/faq/parts/ http://en.wikipedia.org/wiki/Toyota_transmissions Usually the 5th gear is an overrdrive, the % depends on the year it was produced. As far as the odometer, if it a cable or drive gear issue its easy. I've never messed with the odometer innards. Hope that helps. Dirk Quote Link to comment Share on other sites More sharing options...
