millhouse412 Posted April 22, 2011 Share Posted April 22, 2011 So i just bought this bad girl and will be living in her this summer. Everything is working great except for the AC and now the water. AC issue is it is turning on but not fully (no real fan blowing...sounds like it's trying), i think this may be too low of voltage going to her (any suggestions i am open to). The main issue i am have though is that i fully filled the water system and pessurized it with the water pump and then "bunk" i hear something shoot off and water is leaking out of the bottom of the RV. So 1. What are these two drains under the RV....im guessing they drain my water heater and grey water tank (any help on where all my water tanks are would be great) It looks like and easy plumbing fix but just curious about what they are. Thank you all and so glad to find this forum! Quote Link to comment Share on other sites More sharing options...
waiter Posted April 22, 2011 Share Posted April 22, 2011 If they are two small hoses (about the size of your finger), those are probably your winter drains. Cold water and Hot water lines. The valves for my winter drains are under the stove sticking up out of the floor, They have a small "T" handle, Push down to close the valves, pull up to open the valves (drain the lines). My Fresh water tank is inside, under the couch (right behind the drivers seat) , you can see it if you open the cabinets. Black water is all the way in the back in the center between the frames (probably directly under your toilet) Gray is all the way in the back on the drivers side. (Directly under your Shower) Obviously, the Black and Gray are under the RV. The "Dump" valves for the Black and gray are behind the left rear wheel. You'll probably find the drain hose stored inside the rear bumper. If your living in a park and can stay hooked up to a sewer, you can leave the Gray "Dump" valve open to continuously drain your Gray. You don't want to do this with your Black. It usually doesn't drain real time, and will plug up. You'll need to do a Black dump when the tank gets 1/2 full. John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
millhouse412 Posted April 22, 2011 Author Share Posted April 22, 2011 thanks for the reply, now on to fixing that bad boy. Can't get the joint apart so i may be going higher up and redo the entire line...shouldn't be too bad though. I did, however, find some leaks today so there is a fun project. Quote Link to comment Share on other sites More sharing options...
millhouse412 Posted April 24, 2011 Author Share Posted April 24, 2011 Fixed!!!!!!!!!!!!! took forever trying to get that damn crimp off (it was a crimped connection for the plumbing....anyone know a good removal tool...maybe there is an actual tool?) but now have a new drain and the water system holds pressure!!!!!!!!! Next issue though is not being able to get the water heater going. Perhaps another thread after i do some searching. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted April 24, 2011 Share Posted April 24, 2011 Special tool? Dremel with a cutoff disk. Or a BFH!! Quote Link to comment Share on other sites More sharing options...
millhouse412 Posted April 24, 2011 Author Share Posted April 24, 2011 i figured you'd just cut through it, wish i had a Dremel (poor as bleep!) but a heavy pair of snips did the job (eventually). What's that old saying.....? "the right tool for the job" ! Quote Link to comment Share on other sites More sharing options...
tsjeffery Posted May 12, 2011 Share Posted May 12, 2011 If they are two small hoses (about the size of your finger), those are probably your winter drains. Cold water and Hot water lines. The valves for my winter drains are under the stove sticking up out of the floor, They have a small "T" handle, Push down to close the valves, pull up to open the valves (drain the lines). My Fresh water tank is inside, under the couch (right behind the drivers seat) , you can see it if you open the cabinets. Black water is all the way in the back in the center between the frames (probably directly under your toilet) Gray is all the way in the back on the drivers side. (Directly under your Shower) Obviously, the Black and Gray are under the RV. The "Dump" valves for the Black and gray are behind the left rear wheel. You'll probably find the drain hose stored inside the rear bumper. If your living in a park and can stay hooked up to a sewer, you can leave the Gray "Dump" valve open to continuously drain your Gray. You don't want to do this with your Black. It usually doesn't drain real time, and will plug up. You'll need to do a Black dump when the tank gets 1/2 full. John Mc 88 Dolphin 4 Auto any idea where to find replacement valves for the fresh water drains? mine are leaking and there doesn't seem to be an easy replacement available. thanks! Quote Link to comment Share on other sites More sharing options...
waiter Posted May 13, 2011 Share Posted May 13, 2011 I haven't had mine apart, but I think you can replace the o-rings in them?? Have you tried taking them apart?? John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
