Raymond Posted October 21, 2010 Share Posted October 21, 2010 I have tried to find pads, rotor,etc for my 1983 dalphin 20 foot motorhpme. The brake parts for the 1983 hilux 1/2 ton pickup do not fit. Any ideas as I am stuck 300 miles frome home. Quote Link to comment Share on other sites More sharing options...
Diesel_Aggie Posted October 22, 2010 Share Posted October 22, 2010 Call a Toyota dealer with your VIN number. See if they will tell you what part numbers are needed. Then see if NAPA or some other store can cross those part numbers over. Are we talking about front brakes or rear? Where are you stuck? Also have them look up a chassis cab if that is an option. You may have to get an experienced parts counter guy to pull out the paper book and look it up. Some things aren't in the computer and the "button pushers" don't have the thought process or knowledge to fall back on the books. Pulled up www.napaonline.com and put in 1983 Toyota Pickup and search Front Brakes. I refined by 2WD and 22R. I show two distinctly different sets of pads. The larger ones have a note saying 3/4 ton applications. They have 3 lines and I listed the part numbers. 4x4 brakes are different. I think this is your answer. TruStop TS7120 3/4 ton TS7047 1/2 ton Safety Stop SS7120 3/4 ton SS7047 1/2 ton Ultra Premium UP7120 3/4 ton UP7047 1/2 ton Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted October 25, 2010 Share Posted October 25, 2010 I had an 82. It said "3/4 Ton" on the side. They usually use larger brake stuff for greater weight capacities. Ask if they have a 3/4 ton listing. Quote Link to comment Share on other sites More sharing options...
