JohnW Posted July 6, 2010 Share Posted July 6, 2010 Hope this does not post again as I keep getting logged off as I atttempt to write this....anyway I have two tanks on my 1979 sunrader and have no idea how to switch to the second tank. I've crawled under there before but not really sure how it's all put together. Quote Link to comment Share on other sites More sharing options...
Diesel_Aggie Posted July 16, 2010 Share Posted July 16, 2010 Hope this does not post again as I keep getting logged off as I atttempt to write this....anyway I have two tanks on my 1979 sunrader and have no idea how to switch to the second tank. I've crawled under there before but not really sure how it's all put together. I'm guessing here but it seems there has to be some sort of switching valve or solenoid under there that will switch the flow from one tank to the other. This would be something that either Sunrader or an owner installed. Are there any rocker or toggle switches on or under the dash? If so try and trace the wiring and see where it goes. You could also flip the switch and see if you could hear anything clicking under the RV. Next I'd follow the fuel line from the engine back to the tanks and see if you can spot the valve. The 3rd tank on my 96 F-350 has a toggle switch under the dash and a switching valve tapped into the fuel line under the back of the cab. When you flip the switch with the key on and truck not running you can hear a click. Hope this sends you in the right direction. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted July 16, 2010 Share Posted July 16, 2010 Hopefully whatever might be installed (if electrically operated) is designed/approved for flammable liquids. Quote Link to comment Share on other sites More sharing options...
