sunvader Posted September 17, 2009 Share Posted September 17, 2009 Hi Folks, I tried http://www.tweetys.com/ and They don't seem to carry it anymore. I'm looking for the rubber trim/seal that holds the plexi window in place. Quote Link to comment Share on other sites More sharing options...
turtle Posted September 23, 2009 Share Posted September 23, 2009 You should be able to get it through any automotive glass shop. This is the company that makes it but they only sell it in LARGE rolls http://www.trimlok.com/SearchResult.aspx?CategoryID=16 I used the 1 piece gasket when I replaced mine Quote Link to comment Share on other sites More sharing options...
Tony D. Posted September 23, 2009 Share Posted September 23, 2009 You should be able to get it through any automotive glass shop. This is the company that makes it but they only sell it in LARGE rolls http://www.trimlok.c...x?CategoryID=16 I used the 1 piece gasket when I replaced mine Wher can a person by center caps for the wheel on these one ton axle. Especialliy the back ones. I have the one ton with the extended hub and six bolt wheel Quote Link to comment Share on other sites More sharing options...
turtle Posted September 23, 2009 Share Posted September 23, 2009 Wher can a person by center caps for the wheel on these one ton axle. Especialliy the back ones. I have the one ton with the extended hub and six bolt wheel 1 ton front wheel center caps are still available through your Toyota dealer. Pic of stock 1989-1995 (6 lug rim) font center cap is attached. There never was a factory rear 1 ton "hub cap". Some people have used standard 14" hub caps. There are aftermarket stainless steel "wheel simulators" that are still made in small limited runs by the Eagle Flight company (http://www.jaeeagle.com/). They just ran a small run of these so if you are interested you should contact them before they are sold out again. Simulators are like hub caps on steroids. I have simulators on my 1991 Sunrader. On my 1981 diesel (which I have sold) I used silver Hamerite paint. Quote Link to comment Share on other sites More sharing options...
