mytguin Posted August 1, 2009 Share Posted August 1, 2009 Hi, My airbags are not holding air. I am having them looked at on Monday but if they need to be replaced, about how much do they cost? Is it better to get different shocks than the air ones? I had the "regular" shocks replaced last week - what's the difference? I can feel every pebble in the road with the way it is now - probably worse since the new "regular" shocks were put in. I have a '92 Rockwood Roamer. Thanks so much for your continued help! Colleen Quote Link to comment Share on other sites More sharing options...
turtle Posted August 1, 2009 Share Posted August 1, 2009 Hi,My airbags are not holding air. I am having them looked at on Monday but if they need to be replaced, about how much do they cost? Is it better to get different shocks than the air ones? I had the "regular" shocks replaced last week - what's the difference? I can feel every pebble in the road with the way it is now - probably worse since the new "regular" shocks were put in. I have a '92 Rockwood Roamer. Thanks so much for your continued help! Colleen More than likely it is the air lines that are loose or worn. Have those looked at before you decide the actual air suspension has a problem. Do you know what type of air suspension is on your coach? There are a couple out there. Firestone Ride Rite are about the nicest. I heard that they were discontinuing the kits for Toyota motor homes because of their age and lack of sales. You can still get the bags and individual parts for them though if this is what you have. As far as your "rough ride" Check the air pressure. Over inflated tires will ride hard. Weigh the coach and adjust your air pressure based on what is needed in the tires to support the load. Quote Link to comment Share on other sites More sharing options...
T.A.J. Posted August 1, 2009 Share Posted August 1, 2009 Hi,My airbags are not holding air. I am having them looked at on Monday but if they need to be replaced, about how much do they cost? Is it better to get different shocks than the air ones? I had the "regular" shocks replaced last week - what's the difference? I can feel every pebble in the road with the way it is now - probably worse since the new "regular" shocks were put in. I have a '92 Rockwood Roamer. Thanks so much for your continued help! Colleen Look at Timbrens.com I put them on my '84 Dolphin. No more sway!! T.A.J. Quote Link to comment Share on other sites More sharing options...
