Guest Chickens_goreds2#2 Posted August 31, 2008 Share Posted August 31, 2008 I talked to someone here in OHIO tonight and he said he does not use antifreeze. All he does is make sure his water lines are drained dry before the winter and they will not freeze up and bust. Has anyone tried this? Thanks, Quote Link to comment Share on other sites More sharing options...
Kathy Laurin Posted August 31, 2008 Share Posted August 31, 2008 It is not necessary to run antifreeze through the whole system. In addition to blowing out the lines you need to make sure there is no water in the your hot water heater. You do need to add some antifreeze to the ptraps. Quote Link to comment Share on other sites More sharing options...
