GreyDawg Posted July 26, 2008 Share Posted July 26, 2008 Hey guys: My "new" 89 Itasca Spirit has a no evidence of roof leaks, and I want to keep it that way. The caulking around the vents, etc looks good. I don't know if it was ever replaced or is original. What about the roof? I think it is a rubber roof, right? Do I need to recoat or seal it every couple of years? Do I have to take off the a/c and the antenna and the vents to do that right (I envision having some rubber stuff to "paint" on the roof, right?) As you can see, I am sort of clueless here. Thanks, Zack '89 Itasca Spirit Quote Link to comment Share on other sites More sharing options...
turtle Posted July 27, 2008 Share Posted July 27, 2008 That model has a solid aluminum roof. Someone may have put a roof coating on it. You can continue to re-coat it to keep it looking fresh but the coating will not do more than make it look nice as it should not leak. I prefer Dyco 890 as it is an solvent based elestomeric compound with teflon. It stays white longer and the teflon keeps 'crud" from sticking to it. http://www.toymike.com/diesel/pics/fiberglassRoofDone.jpg http://www.toymike.com/forSale/dyco890Front.jpg http://www.toymike.com/forSale/dyco890Back.jpg You "should" remove all vents and stacks, clean the old butyl putty tape off of them, apply new putty tape, and re-install them. This is the proper way to maintain the waterproof seal of these through the roof objects. Quote Link to comment Share on other sites More sharing options...
