nhcamper Posted July 13, 2008 Share Posted July 13, 2008 Does anyone run an electric fan on thier 20R. I just replaced the headgasket on mine and it runs fine but I still think it runs hotter than it should the only part I haven't replaced is the clutch fan. It seems to run fine at 55mph, if I run at 65mph it starts to climb. If I install the electric fan this should help solve the problem I hope. My reasoning for this is the clutch fan replacement is expensive and for less money I can put a flex fan or electric fan on it. Any feeling about this setup? Quote Link to comment Share on other sites More sharing options...
Shoprat Posted July 13, 2008 Share Posted July 13, 2008 Howdy. What temperature is the engine running exactly? If your guage is the old Cold-Hot one, I'd replace it with one that shows it in degrees. Have you checked the radiator and thermostat ? Quote Link to comment Share on other sites More sharing options...
Maineah Posted July 13, 2008 Share Posted July 13, 2008 Shoprat’s right the gauge is vague at best check it with a real one first. I would stick with the stock thermostatic fan it moves a lot of air. Most of the flex fans make a lot of noise and the electric ones may not fit. Quote Link to comment Share on other sites More sharing options...
andreajones021 Posted September 29, 2009 Share Posted September 29, 2009 would stick with the banal thermostatic fan it moves a lot of air.Most of the angle admirers accomplish a lot of babble and the electricones may not fit. _________________ Bathroom fan Quote Link to comment Share on other sites More sharing options...
