guyha Posted April 9, 2008 Share Posted April 9, 2008 Just joined after posting an inquiry about rear brakes and getting several good responses. Thank you. I have another question about the o/d controls. I got info that I should find the E17 ground splice and solder it as a remedy for the o/d kicking on and off and sometimes not engaging at all. The only symptom I was experiencing other than the malfunction was a clicking under the dash , probably coming from the trans relay. Actually the clicking has stopped but the o/d isn't kicking in at all. I replaced the relay but no change. I found a crimped splice connecting 2 smaller black wires to a heavier black wire in the wire bundle just to the rear of the battery tray on the passenger side. I'm wondering if this is the notorious E17. Thanks, Guy Quote Link to comment Share on other sites More sharing options...
