Showing results for tags 'solar panel'.
Found 4 results
  1. I have edited the original post - perhaps the long length of the post was why only 1 person replied to the query? And it has only been a day since I wrote the content.... Regardless, here is the truncated version of the long, flowery, original post: 1. Any suggestions on roof solar panel installation? Or over cab roof install ideas? Solar system is in place already - wkng fine. Just beefing up - need advice on the best method for installing 2 100watt rigid glass panels. 2. Had a flexible solar panel on roof, adhered with duck tape - tape has left residue - need to remove that. 3. Seems roof has minor damage - cracks, small chips, few tiny holes. Would re-fiberglassing the damaged roof areas be the best solution? 4. Am installing a new roof vent - the ceiling vents that manually open and close, no fan on this one. Aside from using butyl tape and lap sealant, does anyone have suggestions on replacing old roof vents? Ok - am hoping by editing out all the conversational elements of my last post perhaps its more readable now and gets more replies, haha!
  2. Well, I did a thing. I bought a 325watt solar panel. It was only $100! But....in all the excitement, i hadnt even considered how i was going to attach this thing to the roof of this 86 dolphin. The rig has one of those thin aluminum roofs with small wooden crossbeams underneath. Getting the solar panel to attach firmly without the wind ripping it off, and possibly the roof, at 60mph is the issue. I've looked into z brackets, but i dont think these alone will suffice. Also considered rails, but trying not to put a dozen holes in the roof for obvious reasons. After spinning over this for the past couple weeks, i figured id consult the wisdom of the forum. Thanks to everyone in advance! (p.s.) im budget oriented and will do the work myself, so costly solutions prolly wont do, thanks!)
  3. Help! Looking for input on how to power my DC circuits with solar - was told by an old RV repair guy that my 200 watt solar panels (1200w inverter) and my (new) deep cycle battery are not adequate to run the DC circuits on my 1988 Dolphin. Said I’d need more batteries, or a generator. Pretty sure I’ve seen setups like this that work?? The Air Conditioner, fridge, and cabin outlets all work on shore power but I only have cabin lights when running on the (new, charged) battery. Any help is appreciated.
  4. While looking at Engle refrigerators I clicked on a link they had for solar panels. http://www.powerfilmsolar.com/products/portable-remote These are something very different than what people are mounting on the roofs. Not an inexpensive item but they do have some real potential for expanding the amount flat space on their rigs that they can mount panels on for the collecting of solar energy. My thought would be for putting them on top of the awnings which will keep them out of harms way and bit harder for thieves to get at them. The 60 watt panel only weighs 5lbs. When you are ready to hit the road take the panel off the awning, fold it up and store it inside your rig. The slope of the awning could be used to advantage to increase solar gain. There is are 10 thru 120 watt versions and units can be combined. they also have roll up panels but only in smaller sizes. It is the folding ones that go up to 120 watts Designed for using in overcast weather conditions which is important to me. Military tested for durability.
