Showing results for tags 'air bags'.
Thought I'd share two minor improvements to the 91 Warrior that I completed recently: Center Caps My rig never came with any center caps on the front wheels (did they all originally, from the factory?), so I thought I'd make use of a recent hobby purchase, a 3D printer, to come up with a solution. Using Fusion360, I spent a crazy amount of time modeling and then printing about 10 different versions of these caps in ABS, trying to find the best way to engineer the retaining clips so that they could a) bend a little b) hold everything securely and c) not break instantly upon installation (harder than it sounds!). I also put the Winnebago logo on the front, obviously, which turned out pretty legit IMO... we'll see how they hold up, fingers crossed. It was a fun project and a great learning experience, especially in terms of gaining beginner CAD skills. AirLift 25804 Compressor Kit It's helpful to be able to adjust your air bags based on how much gear you've carrying and current road conditions. I typically like to run higher pressure (60+) when I'm doing long-distance, interstate travel on excellent highways—just keeps things tighter and less will-nilly, especially when the semis are flying past you, sucking you into that low pressure bubble (we all been there!). At the same time, if you're not carrying a full load or are just moseying around a state park, 40psi seems to be the way to go on my rig. I always bring a 12v compressor and tire gauge of course, but that process can be a hassle and definitely isn't something you can do on the fly! This kit comes with just about everything that you need to add onboard air to your rear air suspension. There are a few different options in terms of installation (some recommended, some probably not), but I chose to put the control panel near the driver's left knee and then ran the 1/4-in air line with 12v+ behind the vinyl flooring and through a sturdy grommet in the transmission tunnel, down to the compressor unit, which I mounted on the rear crossmember. Underneath, I was careful to keep the air lines FAR away from any exhaust components, and I wrapped the lines in a good bit of heat shield insulation where they passed over the transmission. I may also add some kind of "splash plate" over the compressor unit eventually, but I don't think it's going to get a lot of moisture where it is—if any water does intrude, I added some tiny holes in the downward corner of the case for easy drainage. So far, it's working great and will hold the same pressure for many days, no leaks! Also, due to the remote location of the compressor (and some sturdy rubber I sandwiched between it and the frame), it makes very little noise when running. I just really enjoy being able to adjust the bags while driving, to see the impact on ride and handling. (It IS just a single-circuit setup, however, so I can't adjust left vs right, but honestly I rarely ever did that before and don't mind the loss.)
We are at the halfway point on a round trip, 1000+ mile journey to Waco, TX. Engine and tranny are doing well (thank God), but I am dreading the drive home due to the extremely rough ride we experienced today. To explain... This is the first "major" trip we've done in our new-to-us, 20' Warrior, and I worked hard to try and make sure everything was shipshape for the drive (including a brand new set of Nexen SV-820s). We left from our home in SW Missouri and I was very happy with the smooth, relatively quiet highway ride, tested at up to 70mph. All this changed when we transitioned to the roads and highways of Arkansas and Oklahoma; it was virtually a nightmare of continual hammering and banging for many hours. I remember one curving entrance ramp in particular: every eight feet of the ramp was a new slab at a different height, like trying to drive down a massive staircase. My wife and I were both afraid that something might come apart in the process and, sure enough, when we arrived in Waco, we discovered that the oak face frame supporting the shelf our microwave sits on had torn apart from the buffeting. I hope that more damage doesn't surface in the AM, but I don't know... We're both stressed and exhausted. So, am I way off in left field on this? Does this sound like a normal cross-country trip in a Toy RV? I mean, what the hell?! (Btw, I'm running between 60-65mph, tires all near 55psi, air bags at 60psi.)
- 13 replies
