  • Hello Guest
  • Most Recent Three Posts
    • Make sure and get one that has an actual ground wire on it since the camper won’t be grounded by attaching the socket alone.
    • The 26g fresh water tank arrived, and I am still snickering about the randomness of this upgrade.  It replaced the 21g from the factory for a whopping 25% increase in onboard water.  I stuffed it in place to trial fit and it friction fits as if I made the slightly larger space for it, which I did not.  It's slightly larger for more comfortable seating than the factory height.  Here's a picture.  The plywood back of the cushion that covers it actually lightly touches the top of the tank, plus it's shorter and allows more room behind it, and bonus - the weight of the water moves forward a few inches toward the axle and away from being suspended far back on the frame:
    • Good to know.  My plan was not to use a scrap of pine anywhere in this build.  Only Mahogany, Cedar, and the Baltic Birch structural plywood.  Now, doing Poplar drawer faces and a couple cabinet drawers.  Today, I primed about 65% of the interior, as well as the drawers. The rear window frames are out to be painted black like the one by the kitchen for a much more modern look. I even stuck the screws into foam and painted them satin black. Here's the primer going up:
  • Forum Statistics
    13.3k
    Total Topics
    124.1k
    Total Posts
  • Gallery Statistics
    3k
    Images
    12.9k
    Comments
    365
