JustDave Posted February 28, 2010 Share Posted February 28, 2010 (edited) I am thinking about purchasing a 1993 Itasca Spirit with V6 and only 39,000 miles. The unit is generally on good shape with new tires and a new roof air conditioner. The unit has only been driven about 200 miles in the last 2 years due to an illness. I do know the person selling the unit. While I was inspecting the unit I detected a slight miss at low idle. It seemed to go away when I reved it up and I could not feel anything while driving. I have never owned a Toyota before and I was wondering if this was typical or could there be a major problem? I also was wondering about the towing capacity. I need to pull about 1700#'s. Thanks Edited February 28, 2010 by JustDave Quote Link to comment Share on other sites More sharing options...
toyboxII Posted February 28, 2010 Share Posted February 28, 2010 I am thinking about purchasing a 1993 Itasca Spirit with V6 and only 39,000 miles. The unit is generally on good shape with new tires and a new roof air conditioner. The unit has only been driven about 200 miles in the last 2 years due to an illness. I do know the person selling the unit. While I was inspecting the unit I detected a slight miss at low idle. It seemed to go away when I reved it up and I could not feel anything while driving. I have never owned a Toyota before and I was wondering if this was typical or could there be a major problem? I also was wondering about the towing capacity. I need to pull about 1700#'s. Thanks Hi Dave--sounds like you have found a good unit. Can't help you with the engine miss, but why don't you take it to a trusted mechanic and have it checked out. It may be something simple, but if not, how much can it cost to correct it? I say go for it and put your doubts behind you! As for the towing capacity, I think you will find most here will say no towing/no way. Do a search on towing on this forum and you will get lots of info. Quote Link to comment Share on other sites More sharing options...
dogre Posted March 3, 2010 Share Posted March 3, 2010 I am thinking about purchasing a 1993 Itasca Spirit with V6 and only 39,000 miles. The unit is generally on good shape with new tires and a new roof air conditioner. The unit has only been driven about 200 miles in the last 2 years due to an illness. I do know the person selling the unit. While I was inspecting the unit I detected a slight miss at low idle. It seemed to go away when I reved it up and I could not feel anything while driving. I have never owned a Toyota before and I was wondering if this was typical or could there be a major problem? I also was wondering about the towing capacity. I need to pull about 1700#'s. Thanks Sounds like a good find. I have a 91 Spirit. It had 47K miles on it. I've put on 9K this year. I immediately had all hoses, fluids, belts changed and have not had a single problem (knock on wood). I also changed out all tires and had the timing belt and waterpump changed replaced, too. When I took it to my small town mechanic he said "I don't work on motor homes" to which I replied just work on the Toyota part. Now he wants to know how our trips went and what my mileage was. Get a mechanic emotionally invested and you have found a great resource. Towing? Hmmm? Maybe 500 lbs max, but if you do then consider changing over to synthetic lubricants in both the engine and transmission. I'm also looking into adding a heavier rear springs so I don't have to worry about tearing off my very exposed plumbing. The Spirit is one saggy butted rig. A trailer would only exacerbate that. Quote Link to comment Share on other sites More sharing options...
