slocum Posted July 31, 2006 Share Posted July 31, 2006 We have just purchased a 1991 Warrior that has a rear mounted spare tire, we would like to put a hitch on it but are not sure what type or where is the best palce to mount it. Should we move the spare tire or mount under it? Any help would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
Tom W Posted August 1, 2006 Share Posted August 1, 2006 I have the same unit the spare was under the back the orignal owner moved it to the rear bumper,as to adding a hitch I seen it done but you have to figure how to keep the weight off the rear end not much support in the back with (all that overhang) would really have to be done right. Quote Link to comment Share on other sites More sharing options...
bufbooth Posted October 7, 2006 Share Posted October 7, 2006 We have just purchased a 1991 Warrior that has a rear mounted spare tire, we would like to put a hitch on it but are not sure what type or where is the best palce to mount it. Should we move the spare tire or mount under it? Any help would be appreciated. Thanks. I most of the Toyota motorhomes that I have seen, you cannot mount a hitch to the rear bumper due to it being too light / too weak. Actually, in most cases on can not even put a few bikes on the back bumper, the weight of the bikes and the spare tire is too great. You will probably have to have a steel beam welded across the rear most section of the truck frame and then have a 5 to 6 foot hitch extended installed. Quote Link to comment Share on other sites More sharing options...
Tom and Katz Posted November 21, 2006 Share Posted November 21, 2006 slocum, What did you end up doing about a hitch? We have a 1992 Dolphin and are getting ready to have a hitch installed. They will weld in a strenghting bar and then bolt on a receiver hitch, it's $400.00. They said we could pull 1000 pounds maybe 1500. katz Quote Link to comment Share on other sites More sharing options...
86rader Posted March 29, 2007 Share Posted March 29, 2007 I have the same bumper mounted spare. While, it is convenient to have the spare there when needed, how often do you need to access it? I think I will move the spare back underneath and use the tire mount to hold other junk, probably bikes. Quote Link to comment Share on other sites More sharing options...
