1985 Dolphin help
stevenvidito
Hi Everyone,
Thanks for all the info on the forum so far. I just bought a 1985 Toyota Dolphin today. The last owner had disconeccted the coach battery. There are 2 black wires, a red wire with and inline fuse and a white wire. Any help with the negative and possitive placement would be great.
Thanks,
Steve
Howdy ...
Usually the black wires go to positive on the house battery. As does the redwire. White is usually on the negative post. But a good idea would be to use a test light from the wires to ground to make sure.Some manufacturers moved into a grey area here, could be black to ground. Its' best to use the test light and make sure.
