phil1956 Posted October 30, 2009 Share Posted October 30, 2009 have a 1984 dolphin [44000 miles] went on trip all i could go is 50 mph full of water and fuel, on the way back had a little wind , had dumped all my water. all i had was fuel, and all i could go is 55. is this all it can do, or is some thig wrong. thanks Quote Link to comment Share on other sites More sharing options...
turtle Posted October 30, 2009 Share Posted October 30, 2009 Depends on your weight load, going up hill (even just a little bit), and running into a head wind. My diesel would run 50-55 all day long on the flat with no headwind. Even do 65 down hill but going up the other side it was 35 mph and plenty of smoke. You can do the normal things such as a compression check, tune up, new air filter, carb adjustments, etc. But if you are expecting to cruse at 70-75 you need to look for something else. I am able to run 70-75 in my 18' shorty V6 Sunrader but my fuel consumption goes down near single digits. You are best to run on US highways and not on an interstate. Slow down and run 50-55. Less white knuckles and better fuel economy. Quote Link to comment Share on other sites More sharing options...
fsprandy Posted October 31, 2009 Share Posted October 31, 2009 Doesn't sound at all right. Assuming you have a 22r you should easily be able to comfortably cruise at 60-65. have a 1984 dolphin [44000 miles] went on trip all i could go is 50 mph full of water and fuel, on the way back had a little wind , had dumped all my water. all i had was fuel, and all i could go is 55. is this all it can do, or is some thig wrong. thanks Quote Link to comment Share on other sites More sharing options...
phil1956 Posted October 31, 2009 Author Share Posted October 31, 2009 (edited) Doesn't sound at all right. Assuming you have a 22r you should easily be able to comfortably cruise at 60-65. will check timeing and plugs. would like to go at least 63. thanks Edited October 31, 2009 by phil1956 Quote Link to comment Share on other sites More sharing options...
