lagreen Posted August 30, 2009 Share Posted August 30, 2009 Hi all, I have a 1993 Toyota Dolphin and I found out the other day that the horn is not working. I really needed it for a guy that tried to run me off the road in Utah. I looked under the hood for something that resembled a car horn, but to no avail. In this electronic age are horns just an electronic chip somewhere? I checked the fuse for the horn and it is good. Any ideas?? thanks, Barb Quote Link to comment Share on other sites More sharing options...
turtle Posted August 30, 2009 Share Posted August 30, 2009 Your horn "should" be behind the grill at the top passenger side (at least that is what I remember on my 1991). I replaced the squeaky little Toyota horn with a pair of Hella supetone horns (they are LOUD and OBNOXIOUS sounding). This is easy to do but requires using a relay to pull the extra current they use from the battery (everything you need comes in the kit). I have a set of Hadley Bullys that I am thinking of putting in also but I need to get a larger air tank for them Quote Link to comment Share on other sites More sharing options...
lagreen Posted August 30, 2009 Author Share Posted August 30, 2009 Yes, at the point I discovered that the horn wasn't working I was really wishing for a set of Hadleys. Will go out in a bit and look for horn again. Thanks Barb Quote Link to comment Share on other sites More sharing options...
