odysseybernard Posted October 27, 2019 Share Posted October 27, 2019 With hose attached to the bottom nipple no gas drains from hose. Gas only drains from the screw hole if screw is Totally removed. Should it drain from the hose at the nipple?. I may have to install a valve, on off for gas line. Quote Link to comment Share on other sites More sharing options...
