Showing results for tags 'throttle position sensor'.
  1. My TPS connector is worn, the clip is missing, and the plastic is broken. So I started a search for a replacement pigtail. No luck online, although I wasn't exhaustive. My stepson, a certified Kia mechanic in Redding, CA, said it looked familiar and took my TPS to work with him today. He came home with a pigtail that looks like it was made for my 22re. It is keyed perfectly and the pins match up perfectly. The only drawback is that the spring retaining clip is on the manifold side, making it a bit tougher to get off and on than the OEM connector. At any rate, if you're interested, the Kia part number is TKL06-A2700, it's $12 (not sure if that's retail or his price) , and it's a good part number. It's a connector for the ignition fail sensor - not sure what year or model.
