Showing results for tags 'rear axle'.
The short of it is, I just bought a 1981 Sunrader with the dreaded 5 lug bolted together dually rear axle and a broken clutch cable. The owner said the RV started acting weird so he parked it and after he saw online all of the horror stories about his axle he just assumed the axle was the problem and left it parked. So I'm not totally sure if the axle's bad or what but I figured it'd be smart to go ahead and upgrade it. And the clutch cable seems to have gone bad sense it's been sitting. Now, the plot thickens: I live in Roanoke Virginia and the RV is currently in Ohio, up near Youngstown/about an hour from Pittsburgh. My options seem to be: 1. Get the RV towed back home (400miles) and work on it myself. 2. Get it towed to a local shop in OH and be at the mercy of a mechanic that may be untrustworthy/knows I'm from out of town(also, I'm not sure if I would need to take it to just a regular auto repair shop or would it have to be a place that specializes in RVs, like with special lifts and things). 3. Throw that beautiful hail mary, fix the clutch cable myself then see if that axle has at least 400 miles left in it and attempt to drive it back home. My wife and I got it for next to nothing and that's the only reason I figured I had wiggle room to fool with the axle. I'm sure these are questions that have been asked a million times already, but I'm a total scrub when it comes to Toyotas. If I find a replacement rear axle assembly, what year ranges should I be looking for? Do any other rear axles work on these trucks other than the coveted full-float 6 lug? Could I get a more readily available rear assembly from a dodge/ford/chevy and mill a driveshaft adapter? (Only an idea because my uncle is a machinist) I found a rear assembly on craigslist in VA from a 6 lug 1984 4x4 truck, and for the price I'm wondering would something like that be heavy duty enough to take the place of the old/dually axle? This is the link: http://danville.craigslist.org/pts/5369577806.html I have lots of questions and I'd hate to over load everybody right off the bat, but I am just excited to get this thing home. I've been on the hunt for an 18ft Sunrader for 3 years now and this is also our first ever RV haha so thank you for your patience A little dirty but not in bad shape: Here's a shot of the rear end: And here's the hub:
- 16 replies
- rear axle
- suspention
(and 6 more)
With some help from other forum members I figured out my 21ft 1985 Sunrader still has the faulty rear axle. So my question to you all is what kind of rear axles will work with this model? I found a 1989 rear axle, 4x2, double wheel, 1 ton from an old Toyota delivery truck, will this work or is it too wide? If its not going to work, what should I be looking for? Thanks for your help!
Hello! I just got a 1985 Sunrader and I'm not sure if the faulty rear axle has been replaced or not. It kind of looks different from other pictures I've seen, but the 5 lugs have me scared. If it is the bad axle does anyone have any leads on a replacement on the east coast? Thanks!
Trying To Locate A 6 Lug Free Floating Rear Assembly
Katiemccoy posted a topic in General Discussion
We have tried 2 different rear axle assemblies and neither works. Our 1984 New Horizon has a 5 lug assembly that ground to a halt 20 minutes after purchasing the rig - we have scoured junk yards and Craigslist, we have purchased one and swapped it for another and neither worked. Where is the best place to locate one - and how should I start my search - what do I need to ask for? -
Hi, We are swapping our 5-lug rear axle, for the 6-lug one ton, but we do not have the correct size u-bolt or shock plate. Does anyone know the dimensions for these, or whether we can buy universal u-bolt. Thank you, any help is very appreciated! Brittney
- 11 replies
- u-bolt
- suspension
HI Everyone, We are looking for a 1 ton full floating 6-lug rear axle and tires ASAP for our 85 toyota motorhome. We are currently broken down in Kentucky. If anyone knows where we can find one, or has one could you leave us a message, or get back to us at brittymacd@hotmail.com, or 226-236-1342. Thank you so much for your time! Brittney
