Showing results for tags 'heat'.
  1. In the past, I've noticed quite a bit of heat coming off the transmission tunnel and across the whole cab floor in general. So, last month, prior to heading to the Deep South on our biggest excursion of the year, I decided to pull up the original gray vinyl stuff in the cab and add some more heat/sound insulation. (I was surprised by how little was in that area from the factory... pretty bare bones setup under there!) I went with a single roll (36 sq.ft.) of this Siless 157 mil product and a roller, plus some foil tape for the seams. The Siless stuff is like a big, rolled-up sheet of weather-stripping and not the easiest thing to work with, although it does cut nicely with scissors. It basically cannot be repositioned once it touches the surface, due to some very strong adhesive, so I found it worked best to cut roughly 12" x 12" squares and piece them closely together, rolling every inch firmly into the underlying sheet metal, and taping the seams. I splurged and did double-thicknesses all over the tunnel, too. I also ripped out the last scrap of the original, filthy "Pine Mist" carpet that lined the back of the cab and replaced with new, gray low-pile stuff. Very happy with that update. We just returned from our trip and, while the sound dampening improvement is hard to distinguish, the insulation made a huge difference in terms of heat coming off the floor: it's just slightly warm to the touch now, where it used to be surprisingly hot. Wish I'd had an infrared gun to measure the difference, before and after, cause it's very significant. Insulation Installed - Before Taping Finishing Up Install Tip: If you've never had the seats out, you'd better hit those bolts first with plenty of PB Blaster and/or use a torch on them from underneath the truck.
  2. So to start, I want to say that this is my first Sunrader, and my first camper at all. I have no idea what I'm doing just yet but hey, i'm here to learn! Right now i've got my camper hooked up to an extension cord which leads into my parents house. I am in New York, temps are quite cold. I'm wondering whether my heat is broken (I don't think it is because air comes out of the vents) or if there is another adapter/type of extension cord I should be using in order to get the heat pumping in my camper? Please help! Much Thanks and Love
