Showing results for tags 'door'.
I do not know what the original seal looked like that went around the perimeter of the main entry door. The rig came with a worn-out, poorly fitting seal and I’ve tried a couple solutions over the years that have not been great either. The seal needs to allow the door to close and latch fairly easily, without allowing tons of wind to enter while driving. Anyone know what seal was originally used by Winnebago or have a good, modern solution to recommend for this specific application?
The lock on the camper door for my 78 Galavan needs to be replaced. I've read through a few threads here and there, and here's what I've found: The original is a Bargman L-300 There are some replacements out there, like the Tri Mark 33677-01-K and Bauer BP-12RV Measurements Current interior cutout: W 3 7/8 x H 4 3/8 Current exterior cutout: W 4 3/4 x H 4 3/4 Recessed area: W 5 3/4 x H 5 3/8 My entire lock unit is recessed a bit, which I didn't see in photos from other threads, so with the recess I don't think the replacement locks with a rounded shape, like the Bauer, will fit. Is this something The RV Doctor can help with? Thoughts?
Year & Model: . 1992 Toyota Winnebago Itasca Spirit 320RB I want to replace the foam-rubber seal / weatherstrip / moulding that runs around the inside edge of the passenger-side coach entry door. Looks like I'll need about 20 lineal feet of seal. a) . Do I need to use the Winnebago OEM replacement part? . If so, from where do I order it, and how much will it cost? b} . Or, can I use an inexpensive, good-quality, functional equivalent from eBay, Amazon, Home Depot, Lowes, RV Parts Country, Camping World, Autozone, O'Reilly, Napa, or other supplier? c) . Please make suggestions and provide links if you have them. In cross section view, the existing seal resembles a very broad and open "V" shape, with about 120 degrees between the two "wings" or "sides" of the "V". 1) . One wing of the "V" is flat and adheres to the door. . I call this the flat wing. . It measures about 3/32" Thick (in cross section) x 7/16" Wide (in cross section) 2) . The other wing of the "V" is curved [curved concave towards the middle of the "V"] and gets thinner toward the tip of the "wing". . I call this the curved wing. . This curved wing measures roughly 3/32" Thick x 3/8" Wide. . [The convex side of the curved wing is the surface that presses against against the door frame when the door is closed, thus sealing the gap between the door frame and the door.] See attached photo: . In the photo, the seal is standing on the flat wing (adhesive side down), and the curved wing is projecting upwards and to the right. [Note to Website Staff: . As I was creating this post, a spontaneous emoticon kept appearing in place of the characters "b)" . I was finally able to suppress the spontaneous appearance of the emoticon by replacing the text "b) . " with the text "b} . "]
