Showing results for tags 'air lift'.
We enjoed our 1984 Nissan Sunrader over the Summer and finally got new stripes to add to add to the external restoration (Image 1). Now we are going to be taking care of some upgrades that we have found we are in need of as we travel with e-bikes and sometimes a generator. We would like to upgrade the rear suspension and started with some bilstein shocks (Image 2 & Image 3). We did a leafspring update about 2 years ago that brought the rear end up almost level with the front end. Still, we need about a 2 inch lift to match the front which has a ball joint and torque sping lift kit. The new shocks can accomodate the lift and then some, so we feel good about not over extending the shock. We also have an Air LIft kit that we will be installing (Image 4), but wonder if anyone with a Nissan Sunrader has any issues fitting the Air LIft kit around the rear stabilizer bar. We are also looking to install a shackle lift kit (Image 5). Has anyone had any experience doing this on a Sunrader? Image 1: Image 2: Image 3: Image 4: Image 5: The Leaf Spring Shackle kit above is essentially just an extension of the existing leaf sping shackle support bar. We would love to get some input regarding anyone's experience with the items. Thank you.
- nissan sunrader
- 1984 nissan
- (and 5 more)
Took our first trip of the year last week and noticed that the driver's side air bag would no longer hold pressure. Oklahoma roads were, uh, pretty iffy in the rural areas (sometimes, miles of nothing but gravel), and the banging/crashing did not make for a pleasant adventure. Tried the SlimeĀ® option a few times, with very limited success. Well, at least we got home okay, with no other difficulties... So, I got up under the back-end with a spray bottle of soap/water and quickly found a pinhole leak near the top of the bag. I contacted AirLift and explained the problem with my LoadLifter5000 system (P/N 57113), offered to provide photos and all that. Without any question, they took down my address and shipped me a new bag. "Limited Lifetime Warranty" means something after all! I now have the vehicle frame up on 3-ton jack stands and have PB Blaster-ed all the bolts/nuts in the vicinity of the bag, including the dreaded u-bolts. I am monkeying with a jack under the differential in order to raise the axle to the point where "tension is relieved from the leaf springs," as my repair manual puts it. Problem is, I can't tell when that happens. Can somebody provide a little insight here, please? I can move the axle up and down just fine, but at no point is it obvious that the leafs are no longer under tension. Don't really want to start pulling stuff apart until I get this straight. What am I missing? Here's a reference photo, so you can see where I'm at... literally. Thanks for any help!
- 12 replies
- loadlifter5000
- suspension
I've been browsing posts regarding airbags. I understand the benefits for drooping rear ends. Can someone please describe how they affect ride? A prior owner installed two extra leaves on each side of my 1985 Sunrader. Drooping is not a problem, but I'm looking for a way to make the ride a little less stiff in back. Airbags? New or different shocks? Or just live with it?
