Showing results for tags 'led lights'.
Does anyone have a recommendation for high quality LED light fixtures to replace the vintage fixtures in a Sunrader? Thanks!
- 3 replies
- lights
- interior lights
I have this '85 New Horizons which has a circuit panel containing 3 circuit breakers. One of which trips when I plug into shore power. I do not know what ANY of the breakers do, except that one of the two remaining breakers that stay on control electric outlets and all 12 volt systems (lights, water pump, heater fan) kick over to the inverter (you can hear it switch when we plug in). We no longer have an Air Conditioner (removed by previous owner), so I can assume one breaker may have been for that. But the other breaker is unaccounted for. Any ideas? Is a schematic available? Also, we changed all 12 volt bulbs to LED. Since then, they only flicker when turn on while on shore power. They work fine off the battery. I'm thinking the problem is with the LED bulbs - not the system. Voltage at socket when on shore power measures 13.6 volts.
- circuit breaker
- shore power
My wife and I have recently started renovating my grandfathers 1990 Sunrader V6. The front windows leaked (even after having them "professionally" resealed) so I decided to attempt you hand at fiberglassing them in. With only 1 successful posting with pictures that I could find I figured I should get a thread going. We also ripped up the old nasty carpet and tore off the counter top with the awkwardly sized double sinks. We plan on priming / sealing the floor and then laying down some of the locking vinyl hardwood looking flooring. After going back and forth we also decided to update all of the lights to LED lights. I am by no means a professional but I would be happy to talk about this project with others. My wife and I pulled an all-nighter last weekend filling holes, priming and painting the interior. With all the water stains I decided to reseal the windows using butyl tape. I've never used it before but after some research it looked like the best product for this application.
- Fiberglass
- flooring
