Have a small leak from the steering gearbox. Cleaned up everything and drove it and no leaks now. I cannot find any info from my usual sources except the oil and the amount, 400 cc. hope it's not empty, several questions:
1.. There is a 20mm plug accessible from under the hood with a shallow 10mm allen wrench hole and it's pinned,ie a centerpunch was used at the edge, so it probably won't come out easy. Is this the port to add the oil???
2... After much looking at the interwebs I could not find one for sale for the 1 ton pick-ups. I got hold of Tech support for CARDONE who did some searching and said only one they make will be the rite part, # 27-8479 . This is not a part # that most stock so they will not order one. But is this the right part, and is this the only one???
Thanks in advance
