Showing results for tags 'Red Coolant'.
  1. After having my Head Gaskets replaced at a Toyota Dealership my Winnie was returned to me with Red Coolant in the Radiator. When it was still overheating I took it to a Mechanic to have a larger Radiator installed, The mechanic came out and asked if it okay with me if they use Green Coolant, I said sure makes no difference to me. After having the new radiator installed I took it for a test drive and it overheated worse than before the newer bigger radiator? I decided to drain the existing "Green Coolant" to try a product called "Water Wetter" by Red Line. In the process of draining the coolant I discovered that there was still "Red Coolant" in the system. Not only did the red and green not mix, they stayed separate. I got green coolant from the radiator and red coolant from the block. Now I wonder if this issue with the red and green coolant being used together may have been why I continued to overheat, or if the new Distilled Water and "Water Wetter" is really why I am now not overheating? Does anyone have experience that may lead to a conclusion?
