HannahSunrader84 Posted November 27, 2016 Share Posted November 27, 2016 I am still having trouble with the side windows in the cab over (not a wraparound) I resealed them properly (removed, cleaned, butyl tape, re installed) I got a good "squish" of butyl around the outside. The seam is good, the water seems to coming in from the place that the window slides. Any advice? I'm super frustrated. I haven't been able to find any drain holes, is that my problem? I'm planning on further investigation today, but would love some help! Thanks. Quote Link to comment Share on other sites More sharing options...
linda s Posted November 27, 2016 Share Posted November 27, 2016 So hard to figure out what I can't see. Pics? might help. There have to be holes somewhere. Are the windows upside down? Not saying you did it but some owner in the past could have gotten them mixed up. Linda S Quote Link to comment Share on other sites More sharing options...
HannahSunrader84 Posted November 27, 2016 Author Share Posted November 27, 2016 I'll try to get since pictures. They are not square so they only fit one way. Just knowing that there have to holes helps. Thank you! Quote Link to comment Share on other sites More sharing options...
linda s Posted November 28, 2016 Share Posted November 28, 2016 Had to look up pics. yeah your east coast model does have the slant in the front of the side windows. They are bigger than my side windows on my wrap around front one too. Not the best time to have to fix windows but there are a few possibilities. Seal where the side that opens slides against other glass. Glass seal to frame. That glass is sealed to the metal just like a windshield. You can see it best by lifting some of the glazing bead. That stuff looks like rubber seal in a channel of the frame but doesn't really seal anything. Wish I could help more. Most likely plugged holes though. water get in the slider window channel and if it can't get out it overflows to the inside Linda S Quote Link to comment Share on other sites More sharing options...
86rader Posted November 28, 2016 Share Posted November 28, 2016 Linda beat me to the "are they upside down question". I recommend you get everything good and dry, get inside with a flashlight when it is pouring rain. Someone outside with a hose would do, I guess. Just make sure the water is hitting in a normal downward direction. And watch. Quote Link to comment Share on other sites More sharing options...
HannahSunrader84 Posted November 28, 2016 Author Share Posted November 28, 2016 Thank you! Quote Link to comment Share on other sites More sharing options...
