Lias Posted June 17, 2016 Share Posted June 17, 2016 Hi, the water inlet for hooking up a hose leaked all over during my last rv park stay and I'm pretty sure it's the original. I found this on Amazon and was thinking it should fit but was hoping someone on board would be able to confirm. The holes look in about the right spots. https://www.amazon.com/gp/product/B005947Z3M/ref=ox_sc_sfl_title_4?ie=UTF8&psc=1&smid=ATVPDKIKX0DER Thank you! Quote Link to comment Share on other sites More sharing options...
jjrbus Posted June 17, 2016 Share Posted June 17, 2016 I have a 94 Sea breeze and the link you show would fit mine. However there are female and male threads. On the inside where it connects (the opposite end of the hose) If the threads are inside it is considered female and it the threads are outside it is considered male. Buying the same one would make installation simpler! Did you try replacing the washer in the old one and making sure the end of the hose is round? These things are basic and is usually a bad washer or end of hose deformed, not saying they do not go bad. Your link is a female and the one below is male. Quote Link to comment Share on other sites More sharing options...
DanAatTheCape Posted June 18, 2016 Share Posted June 18, 2016 (edited) before you tear into it, I suggest you try this easy check - push in the reed valve (with system pressurized - turn on pump pressure switch) . If any debris, sand etc is in the reed valve it will leak. If you do as I suggest, water will blow out and clean the crap out. Worked once for me -- 93 winniie warrior. Another work around is to get a screw on cap - I keep one on mine. check this: http://www.homedepot.com/p/Orbit-3-4-in-Threaded-Hose-Caps-2-Pack-27902/100659301 Edited June 18, 2016 by DanAatTheCape Quote Link to comment Share on other sites More sharing options...
Lias Posted June 18, 2016 Author Share Posted June 18, 2016 (edited) Thank you both jjrbus and DanAatTheCape for the feedback! I will take a look at the valve ( I had no idea about the fe/male threads) and try the easy check. I do appreciate your taking the time to write back. EDIT: I didn't check the washer either. Edited June 18, 2016 by lsabug forgot something Quote Link to comment Share on other sites More sharing options...
jjrbus Posted June 18, 2016 Share Posted June 18, 2016 No thanks needed, I get so much help from these forums I am happy to have a chance to pay back! Jim Quote Link to comment Share on other sites More sharing options...
