Can't see why it couldn't be imported. But it appears to be designed to only fit one car: Opel Astra.
Soon to be coming to America as the Chevy Cruze in 2016.
I wonder if it would fit on a Prius. Also wonder if they can be imported.
Linda
Why would anyone want it on a Prius?? I just watched a road test of a Prius pulling a moderate load at highway speed and it got 17 MPG. Vehicle tested along side of it with a 4 liter gas engine got 19 MPG. Considering the resources used, start to finish, to build a Prius - it's probably one of the most inefficient, earth "unfriendly" cars ever made. Prius works well enough when used only for what it was made for - and gives the illusion of efficiency when all it takes to build it is not factored in - but I suspect a Toyota truck would beat it for efficiency when being worked.
The Chevy Cruze coming to America in 2016 does not have the same body shape as the car this camper mates to.
This camper can't be used with any other car as the profile is specially molded for an exact contour fit to a very specific vechicle so no fitting on a Prius. They would have to offer different versions of the camper for different specific cars for it to work.
Well I bet I could get it to fit any number of little cookie cutter vehicles made today but unless you find one older than 25 years it's not coming to this country. No DOT sticker no entry
A little more research on the subject. It is not the 2016 Chevy Cruze that is potentially going to be the US market's near clone of the Astra. Its the 2016 Buick Verano/Excell. But since it does have some body redesign from previous years who knows if it would fit the camper. A much more similar vehicle as this is the car that actually was based on the Astra.
http://www.worldcarfans.com/114051575339/2016-buick-verano--excelle-spied-for-the-first-time
