kris Posted March 27, 2005 Share Posted March 27, 2005 Hello, I am a new owner of an 82 Sunrader. I think that this is the first of many questions to come... Hope someone can answer----I thought that I had the reg. 17 gal tank as the 23 yr old papers that came with my sunrader didn't say any different however I was day dreaming at the gas pump the other day, the first time I put gas in it and low and behold I had put in 21 gals., Does this mean I have the larger tank I didn't see any gas coming out anywhere. Also dumb question #2: Since the gas pump goes into the side kinda pointing up will the pump cut off itself or do I have to guess when it is close to full? Thanks Kris Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted March 28, 2005 Share Posted March 28, 2005 Hi Kris Look under to the left of the filler. If you have the larger 26 gallon tank you will see a square steel tank. I think the stock 17 gal tank has very rounded edges and corners. Mine shuts off when filling but sometimes spills some gas. I find that for mine to fill I have to turn the nozzle upside down. Greg Quote Link to comment Share on other sites More sharing options...
dinocamper Posted July 21, 2005 Share Posted July 21, 2005 Hi Folks There is 231 cubic inches in a gallon size cube. So a usable estimate even on a rounded corner tank can be had by length X width X hight (all in inches) divided by 231 lol Quote Link to comment Share on other sites More sharing options...
