Jholker Posted May 27, 2014 Share Posted May 27, 2014 Can I recharge my rooftop AC?? It is a carrier 13,500 btu unit. I would prefer to do it myself if possible. What type of freon does it use? Quote Link to comment Share on other sites More sharing options...
linda s Posted May 27, 2014 Share Posted May 27, 2014 The older ones use R22 the same as a home refrigerator. There should metal tag somewhere on it stating what refrigerant was used. I don't know if you can even buy it. Also it must be leaking somewhere so that would have to be found and repaired. Linda S If it's a newer AC unit, 1996 or later, Carrier switched to something called puron R410A Quote Link to comment Share on other sites More sharing options...
Jholker Posted May 27, 2014 Author Share Posted May 27, 2014 Thanks Linda S It is a newer model but not sure yet what year. I will take the exterior cover off and look for tag and charging port. It blows cool air but nothing like I believe it should. Thank you for the quick reply!! It sits on top of a 1991 Dolphin Seabreeze, but is not the original AC Quote Link to comment Share on other sites More sharing options...
linda s Posted May 27, 2014 Share Posted May 27, 2014 Best price I could find on a 410 recharge kit if yours is one of the ones that uses it http://www.horticulturesource.com/product_info.php?products_id=16356 Linda S Quote Link to comment Share on other sites More sharing options...
zero Posted May 27, 2014 Share Posted May 27, 2014 Can I recharge my rooftop AC?? It is a carrier 13,500 btu unit. I would prefer to do it myself if possible. What type of freon does it use? Unlike the AC systems with compressors under the hood - roof-top AC units have no rubber hoses to leak. At least, none I've seen. My point being is that when refrigerant is low on that type of AC unit - it's more apt to be something major as opposed to a few -o-rings or rubber-hose problem. if you haven't done so already - It would behoove you to do a good vacuum test and a pressure test before trying to recharge. That is unless you get refrigerant cheap and don't mind if a recharge does not work. Doesn't hold much. Probably 15-18 ounces of R22. Some of the roof-top AC unit have no charge valves like the AC system does under the hood. If not - add-on piercing-valve might have to be used ($5-$10 item). If the system is totally dead- you shouldn't add refrigerant until you pull a vacuum on it and boil out any moisture in there. Quote Link to comment Share on other sites More sharing options...
Jholker Posted May 27, 2014 Author Share Posted May 27, 2014 Thank you for your reply, I have read every thread on this forum, some several times, and I feel this is the BEST FORUM ever!!! Thanks to all you great Toy owners. I have a 1991 Dolphin Seabreeze that I bought for $2000 with generator V6 engine and the only thing that I found is one wall has dry rot, easy fix for me. Love it and fun to drive!! Quote Link to comment Share on other sites More sharing options...
Maineah Posted May 28, 2014 Share Posted May 28, 2014 Check your discharge temp at the vent if it's in the 40* range it's all you get MH's are hard to cool sitting out in the sun the best mine ever did was lower the humidity and the temp maybe 10-15 degrees. Quote Link to comment Share on other sites More sharing options...
twoblocked Posted May 28, 2014 Share Posted May 28, 2014 Can I recharge my rooftop AC?? It is a carrier 13,500 btu unit. I would prefer to do it myself if possible. What type of freon does it use? What symptoms are you having that indicate you need to recharge? Quote Link to comment Share on other sites More sharing options...
Jholker Posted May 29, 2014 Author Share Posted May 29, 2014 Two blocked The air just does not seem like it is cold enough, other than that it removes the humidity real well, the water runs off the roof when the AC is on. Maineah I think the air temp it blows is more like 50 degrees, but I will check when I try it next time. Thanks for your help!! Quote Link to comment Share on other sites More sharing options...
WME Posted May 30, 2014 Share Posted May 30, 2014 The typical RV roof AC will only show a 20-25 temperature drop when its running. We're talking about room temp vs AC outlet temp Quote Link to comment Share on other sites More sharing options...
twoblocked Posted May 30, 2014 Share Posted May 30, 2014 Two blocked The air just does not seem like it is cold enough, other than that it removes the humidity real well, the water runs off the roof when the AC is on. Removing humidity is hard work for any AC unit. Make sure you have all the windows and vents closed in your RV. You want to re-circulate the air inside and not bring in any outside air that will require extra work to remove humidity. If water is running off the roof I'd say the unit is operating pretty well. It's just that you have some tough conditions for an AC. (i.e. high humidity) maineah and WME have the right idea. Take temperature readings in the coach and the discharge at the AC. A 20-30 degree differential is about all you can expect. Quote Link to comment Share on other sites More sharing options...
linda s Posted May 30, 2014 Share Posted May 30, 2014 Yes if it's cooling don't mess with it. The humidity it removes cools the body just as much as the cold factor. 90 at 90% humidity is really hot but 90 in the desert can be quite comfortable Linda S Quote Link to comment Share on other sites More sharing options...
Jholker Posted October 31, 2014 Author Share Posted October 31, 2014 After playing around with the A/C this summer I took off the exterior shroud and seen that nothing under the cover was insulated from the heat of the sun. I took bubble wrap and contact adhesive and wrapped all areas that were cool to the touch (with in reason) What a HUGE DIFFERENCE it made. Now the compressor seldom runs and it is COLD in my toy. Bummer time to put her in storage for winter:-( Quote Link to comment Share on other sites More sharing options...
Totem Posted October 31, 2014 Share Posted October 31, 2014 Also if you suspect a leak ... go to walmart and buy a cheapo college kids black light. r22 glows like the predator being shot by Schwarzenegger. If its leaking you will see it with the black light at night and can determine if it warrants further work/money or replacement. Quote Link to comment Share on other sites More sharing options...
