Larry Posted December 2, 2004 Share Posted December 2, 2004 I have a '92 Warrior, 6 cyclinder. There is no carpeting in the cab, just the vinyl floor covering. The transmission hump between the seats gets really warm - almost hot. You sure couldn't leave a candy bar close by. Is this normal? Quote Link to comment Share on other sites More sharing options...
Gulfstream Greg Posted December 3, 2004 Share Posted December 3, 2004 Larry I would say yes its probably right. With out the carpet as insulation the transmission heat will radiate into the cab. Auto transmissions can easily reach 220 degrees. Thats allot of heat. Greg Quote Link to comment Share on other sites More sharing options...
WME Posted February 24, 2005 Share Posted February 24, 2005 I went to Home Depot and got a roll of the Refeletix insulation. Removed the seats and pulled up the floor cover. Using the special tape I laid a piece over the trannie hump. Then cut and laid another layer over the whole cab floor . Reinstalled carpet and seats. It made a big difference in the amount of heat comming in. Quote Link to comment Share on other sites More sharing options...
