Bubble Window Replacement on Mirage
o*Live
 Share
Frame is in pretty tough shape the guy that owned it got stuck with it as his only Daily driver and New England winter for a few years in the salt did a number on it but yes 1000% I love this thing I’ve been traveling all around town with it and I will definitely get it repaired and keep it for a long time I think
  • Replies 93
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I apologize if this is off topic, but I just picked up an 85 Sunrader on an 84 chassis, and the windows are not wrap-around. They are two individual flat windows. What is the difference between mine, and the bubble ones? Thanks all!
Yours was made by a different division of the companies owned by Stewart Gardner. Flat windows Monterey  Leisure in Elkhart Indiana. Wrap around windows made by Sunrader in Vallejo Ca. There are also differences in interior detail.
I’m sorry that I’m still posting different subjects on this window thread but I can’t seem to navigate this site and I just have a simple question I’m taking my first little road trip tomorrow about 2 Hours Dr. in my 1986 Mirage. I need to know what tire pressure I should run my tires say maximum 65 psi now I’ve read here that they should be 50 minimum but the previous owner has a sticker on the dashboard that says psi tires 28 I don’t know why he would have that he drove the truck for 25 years with that tire pressure I think what should I do? Real time if I could get an answer at some point in the morning I guess
Thank you Linda you have been invaluable to me in this whole process I will send pictures of mine little day trip if that’s appropriate I don’t know where to post now what part of this website. Now if I can just figure out how to get out the inner rear tires to get air in them:)
Edited by Ragtop
If you scroll down on the home page you will see a section that says trip reports. That's where you tell us about your trips.
I don't remember if we covered your left hand thread lug nuts on the drivers side rear. If not please know that those lugs only unscrew the wrong way. Clockwise is off, counter clockwise is on. Never forget that.
Gas station air hoses have always been a problem for me. I have always used a small portable air pump like this
12v 100 PSI High Volume Air Inflator (harborfreight.com)
Unless you have really big hands you should be able to reach in and screw it onto your valve and turn it enough to fill the inside facing outside tire valves.
Not a bad location for my very very first time ever in an RV. And I love the fact I can take my Vespa with me:) I think I could get to like this thank you for all your help everybody
Thanks in no small part to all the help here!!!
I don’t know why to my knowledge  nobody makes these fold up brooms anymore  very useful for our world I think   I found this in an old house I was demoing
Actually a couple of years ago when I looked no one made it now there’s a couple of telescoping ones of course with Amazon anything is possible. :(
I just purchased a 1984 Toyota Mirage and I am looking for someone that can make these windows.  The ones in it are in rough shape.  I know this is an old post but I thought I'd try.
Thanks
No one that I know of is making these. The Mirage is so rare there just isn't enough demand for someone to continue doing it. Best case scenario is to find someone who does custom plexiglass molding. You would have to remove the windows first and probably send them somewhere if you found someone. If they are severely cracked you would need to glue them back together before you removed them, super glue very carefully in the cracks.
All this will be expensive and time consuming and if the company you find does a bad job you're going to end up with no windows at all
I finally got under my rig today and got it on a lift the frame is in horrible condition I’m going to stay local do a couple of close little trips and then over the winter I’m going to have to figure out a restoration project or maybe try and find another 86 Toyota and do a frame swap or a truck swap any help or advice on this would be greatly appreciated
If anybody could steer me to the right forum I need people that can tell me what year frame would be the same if I could just take my dual rear end and stick it on a different truck what years are compatible this is going to be a Herculean task but the few times I have used the Mirage it’s been so pleasant
Check your wheelbase. Pretty sure it's 112. So, grasshopper, more than Herculean. Just the frame would be a frame off restoration. Are you equipped for that? Engine, front end, steering, cab, all electrics  would have to be installed. Just to move your camper to another truck you can use any long bed, regular cab truck from 1985 to 1994 or 95 not sure what year the fuel filler changed sides.
Yes you can move your dually over to the new truck but most of them will have 15 inch wheels. Maybe you should save yours.
Best case scenario would to get a V6 4x4 but then your going to need to buy custom 15 inch dually wheels, about 250 each plus shipping from California. No 14 inch wheels with 4x4 lug pattern and wheels must match
Or you could see about reinforcing your existing frame. It can be done. I've seen it on a crazy Sunrader with articulating suspension. A true overland camper
Probably cost thousands less than the new truck option
Bajadulce's thread is the best here to show you what's involved
How close are you to seacoast NH?
26 minutes ago, J. P. said:
I am I don’t know one hour from seacoast New Hampshire I’m in Boston
Frank’s Garage in Hampton, NH. Does frame repairs, extensions and frame fabrication. All work is done in house.
This is the only shop I will trust with my motorhome. There may be a wait as he’s usually very busy. His landline (603) 926-4900. Worth the trip !!!
Thank you I will give him a call.
 Share
