5Toyota Posted November 30, 2011 Share Posted November 30, 2011 what is the horse power of the stock 22re cant find out Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 30, 2011 Share Posted November 30, 2011 "The first fuel injected 22R-E engines appeared in August 1982. Output of these engines is commonly rated at 105 hp (78 kW) at 4,800 rpm and 137 ft·lbf (185 N·m) at 2,800 rpm." http://en.wikipedia.org/wiki/Toyota_R_engine Quote Link to comment Share on other sites More sharing options...
tumolt Posted November 30, 2011 Share Posted November 30, 2011 http://www.4x4wire.com/toyota/faq/parts/ and scroll down to view engine specs, rear ends, and trannys. Add this site to your favorites. Quote Link to comment Share on other sites More sharing options...
5Toyota Posted November 30, 2011 Author Share Posted November 30, 2011 thank you Derek and tumolt Quote Link to comment Share on other sites More sharing options...
Derek up North Posted November 30, 2011 Share Posted November 30, 2011 I guess I should have also posted this (also from Wikipedia): "In 1985, the engine was significantly reworked, output was up to 112 hp (84 kW) at 4,600 rpm and 142 ft·lbf (192 N·m) at 3,400 rpm. Many parts from the newer 22R-E are not compatible with those from the older pre-1985 engine. Non-compatible parts include the cylinder head, block, pistons and many of the associated parts such as the timing chain and cover, and water and oil pumps (although the oil pump internals are the same). These changes also affected the 22R, therefore one can consider the 85-95 22R-E as a fuel injected version of the 85-90 22R with only minor differences, if any." Quote Link to comment Share on other sites More sharing options...
5Toyota Posted December 1, 2011 Author Share Posted December 1, 2011 Derek thanks as i have 1988 22re 4wd xtra cab and just bought a 1987 21 foot 22re dolphen 66 ooo miles . Quote Link to comment Share on other sites More sharing options...
