So does my 1985 have the "foolies"? If so how much is this to typically replace and what axles and parts to go with? Sorry for the bad picture. Its the best I haveIMG_20260927_110759_638.jpg.39b6bf8a05480721d2672d461ce824af.jpg
Once again, uploaded upside down and I don't know why.
If your axle uses 5 lug wheels, it’s a foolie. Full float axle has 6 lugs and a protruding hub.
Your wheel appears to be 5 lug.
Find the weight over the rear axle. If under 4K lbs. you could run singles. I would need more specifics before making any recommendations.
It would help if you post a picture of your rig along with a closeup of the rear axle.
Edited by fred heath
Nice! Thanks for the info. I will have to find out the weight over the rear axle. 1790452070713.jpg.16ec046cf8d1bc842a30f5a5e91ed654.jpgIMG_20260927_100427_670.jpg.bc44539736a73229fd6e03d066da8f2e.jpg
Here's a pic I have of sort of the rear axle. I'll have to take better pics when I have time. Sorry for the upside down picture. They won't upload right side up.
Thanks for the picture of your Rig. It looks in good shape.  Unfortunately though, it shows your rear axle with the Hubcap on. In order for folks here to answer your question you need to take a picture of your rear wheel with the Hubcap off.
Are there any examples of what single wheel to run on the rears?  Obviously at that weight on the rim it would be great if anyone knows of a hub-centric wheel to better distribute the weight, but I'm interested in whatever folks have used.  Thanks.
Toyota wheels are lug- centric. Any 5x4.5 bolt pattern wheel will work.
As long as the wheel fits flush to the drum you’re good to go.
I’ve used inexpensive white wagon wheels from Sumit. Everything will have hubcaps, so wheel color is not important.
Thanks! Yes I know. Thats an older picture. I will have to pop off the hubcap when I have time. I have more pictures so I'll see if I can find one where I had the hubcaps off
The rear wheel looks like a 5-lug non floater.  Not the greatest photo (distance and angle) of the rear wheel/axle, but that's what I'm seeing.  As suggested, go to a nearby scale and find out how much weight you have on the rear axle.
Sounds good. Its not in drivable condition right now so I'll have to wait until I have it drivable
You have the 5 lug axle. My guess is based on the dimensions I’m looking at, you’re going to be too heavy for single wheels.
Axle swaps can run into thousands of dollars. It’s my understanding that replacement axle shafts are still available for that 3/4 ton axle. A less expensive option might be to replace the original shafts with new. It won’t be a full float, but will have the same safety factor as when your rig was new. Versus 40 year old shafts.
Take your VIN to a Toyota dealership. Find out if those shafts are available where you live. You can also go to online Toyota parts dealers.
It sounds like you’ve got your hands full with interior work. Good luck.
OK good to know! Yeah there's a lot of interior (and mechanical) work to be done before I focus on the axle. If it stops snowing and warms up even a little I can do some more work on it. Until then it sitting in the field for another day! :)
New axles if possible, next choice is used axles off the lowest mileage pickup you can find.
In either choice 10 psi more in the inner tire.
5 hours ago, CanadianYoterHomeAdventures said:
I'll be on the lookout for some axles!
You need axle shafts that fit your truck. Toyota made 1/2 ton and 3/4 ton axles. The two sets are not interchangeable. Most pickups use the 1/2 ton axle. The 3/4 ton axle was used primarily in cab and chassis applications (i.e. motorhomes).
This is where your VIN becomes important. It will list what axle you have. Armed with the factory part number you are good to go.
I recommend buying new. Any used axle shafts that fit probably came out of another motorhome.
Plan on new wheel bearings and seals. The bearings are press fit to the shaft. None can be reused.
Sounds good!
