starhunter21 Posted March 28, 2010 Share Posted March 28, 2010 I just picked up a 1979 Dolphin and need to replace the fuel pump in the rear gas tank. Could someone please point me in the right direction. Thanks, jon Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 30, 2010 Share Posted March 30, 2010 Sorry, but I'm not familiar with the '79 setup, but IF the pump isn't actually in the tank you can go to Autozone/Advance/NAPA and get a generic in-line replacement pump for $40-$50. They usually are available in 2 different pressure ranges. Hopefully someone here will be able to tell you what the correct pressure is for your '79. Quote Link to comment Share on other sites More sharing options...
starhunter21 Posted March 31, 2010 Author Share Posted March 31, 2010 Well, I got the correct part number from the toyota dealer, but there are non available (been discontinued). Other than replacing the whole tank with a new pump and gas gauge system, anyone know of a source for old fuel pumps? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 31, 2010 Share Posted March 31, 2010 So the fuel pump is in the tank? If you've got the part number, you could start by Googling it. And searching the P/N in the various Toyota Forums. And of course there's always EvilBay. Sometimes a pump installed out of the tank is capable of pulling fuel through the intank, dead pump. I've no idea if that's the case here. Just throwing ideas on the table. It would be a shame to replace a perfectly good gas tank just because the fuel pump isn't working. Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 31, 2010 Share Posted March 31, 2010 http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/subcategory_Fuel-Pumps-and-Tanks_-49997361_-49997327_10151_10051_-1___ Quote Link to comment Share on other sites More sharing options...
starhunter21 Posted March 31, 2010 Author Share Posted March 31, 2010 So the fuel pump is in the tank? If you've got the part number, you could start by Googling it. And searching the P/N in the various Toyota Forums. And of course there's always EvilBay. Sometimes a pump installed out of the tank is capable of pulling fuel through the intank, dead pump. I've no idea if that's the case here. Just throwing ideas on the table. It would be a shame to replace a perfectly good gas tank just because the fuel pump isn't working. I have the part number and it is no longer available. I have been searching all over the web. So, I think my next move is to find a gas gauge that will fit in the fuel tank from another year of toyota, or other. All I need to make sure is that the correct ohm from the stock electrical. THen I will mount an external fuel pump on the frame. Now all I need is the directions? Quote Link to comment Share on other sites More sharing options...
Derek up North Posted March 31, 2010 Share Posted March 31, 2010 Have you tried:- http://car-part.com/index.htm Quote Link to comment Share on other sites More sharing options...
Maineah Posted April 1, 2010 Share Posted April 1, 2010 Derek is right a good pump will pull fuel through the bad pump worst case remove the old pump and just use the pickup tube and put the housing back in you may have to add a little extension. It is a low pressure pump, mount an external pump low as you can safely and use the existing wiring. This thing has two pumps? Quote Link to comment Share on other sites More sharing options...
motoyhomme Posted April 5, 2010 Share Posted April 5, 2010 What about the Airtek Part number E8188? http://www.rockauto.com/catalog/raframecatalog.php?carcode=1277119&parttype=6256&a=FRc1277119k59943 Allen Quote Link to comment Share on other sites More sharing options...
MAXXFabrication Posted May 8, 2012 Share Posted May 8, 2012 it is an external electric pump on the 20R, the head had no provisions for a mechanical fuel pump (a few did) the late 20Rs did though electric pumps were used on the trucks until the late 8122R which had a head mounted mechanical pump. Quote Link to comment Share on other sites More sharing options...
5Toyota Posted May 9, 2012 Share Posted May 9, 2012 max what about the fuel pump reszister under the hood on the left side one toyota mec told me those were problematic but i never had a problem with 1977 20r corona or 1978 minimax is he shure it is the pump and as i remeber the sending unit is not partof the pump . wo nder if BOSCH would havea pump that would work exteranel or in the tank Quote Link to comment Share on other sites More sharing options...
dolphinguy Posted May 14, 2012 Share Posted May 14, 2012 i have a 79 dolphin that had a fuel pump problem.i installed an electric pump on the fender well.it does pull fuel through the old pump.my gas guage works.but the gas mileage suffered badly.i now get approx. 12 mpg.but it does run. Quote Link to comment Share on other sites More sharing options...
waiter Posted May 14, 2012 Share Posted May 14, 2012 The only thing I could think of that would cause this would be if you got a Fuel Injection pump (60psi) instead of a Carb pump (6 psi), and its able to push fuel past the card bowl. However, if this was the case, I suspect the the engine would be running very rich. John Mc 88 Dolphin 4 Auto Quote Link to comment Share on other sites More sharing options...
Derek up North Posted May 14, 2012 Share Posted May 14, 2012 I agree, but it might not be a fuel injection pump. If you're using one of the 'cube' electronic pumps, they're generally available in 2 different pressure ratings. One's 1-3psi, the other 4-6psi (generally). I'd check what you've got installed and try to find out what pressure you need. Do you have the stock carb or a replacement Weber? Quote Link to comment Share on other sites More sharing options...
dolphinguy Posted May 15, 2012 Share Posted May 15, 2012 you guys got me thinking so i went and checked the pump.i cant read anything except that it says for a 6 cyl.it has the stock carb.i will look for another pump thats better matched to my 4 cyl. thanks Quote Link to comment Share on other sites More sharing options...
5Toyota Posted May 16, 2012 Share Posted May 16, 2012 toyota never made sixs with carbs for shure sort of slipped my mind on that 20r as i rember the stock carb has 2 fuel lines if it does i think one takes exces gas back to the tank acording to my old 20r book1975 to 1979 used the electric pump in the tank the SPEC IS PSI 2.1 to 4.3 psi FLOW RATE IS 1 and 3 eights QUARTS per MINUTE. yes facing the bowel window the twin gas hose fitting left is intake to the right is return to the tank. I HOPE THIS HELPS YOU to high pressure will cause flooding. ANOTHER OLD TIME ADD On THING WAS A IN LINE AFTER MARKET ADJUSTABLE FUEL PRESSURE REGULATOR DONT KNOW IF YOU CAN STILL BUY THEM Quote Link to comment Share on other sites More sharing options...
5Toyota Posted May 16, 2012 Share Posted May 16, 2012 WAITER FROM THIS EVEN 6PSI WOULD SEEM TOO MUCH Quote Link to comment Share on other sites More sharing options...
fred heath Posted December 11, 2012 Share Posted December 11, 2012 My 1979 is on a 1978 chassis. The Airtex Master #E8188 as motoyhomme stated is the correct pump. I got mine through AutoZone (chain store) for $63.99. It also fits the 1979. I have not installed it yet,so can't offer any advice there. Good Luck. Quote Link to comment Share on other sites More sharing options...
