granthum Posted April 27 Posted April 27 Recently came to acquire an '86 factory 4x4 Sunrader that is in serious need of a suspension refresh. I know the Old Man Emu CS010R is the go-to for folks around here for leaf spring replacement - but all of those threads seem to be talking about the 2WD models. I know the 4x4's sit a bit higher so my assumption would be that they need different springs, but truly, I am out of my depth here. would be grateful if anyone has any information! same question in regards to shocks, too... Quote
MaineJed Posted April 28 Posted April 28 Should be able to find the factory specs and get a leaf pack from most anywhere that sells springs or a lift kit company. Also just measure the shocks and get some good aftermarket ones. Quote
Odyssey 4x4 Posted April 28 Posted April 28 There is a “frame and axle shop” near me that custom builds leaf packs. They typically work on fire trucks and large rigs but they did my alignment on a previous toyota camper. I think if you load your sunrader up with a weight you’d expect it to be when loaded up and then go have it weighed, you’ll get a front and rear axle weight. Take that number with you to a shop that builds leafs as well as your old leaf pack and they may be able to custom build you a pack. Quote
