shaunydaun Posted April 3, 2025 Posted April 3, 2025 Good Morning Campers! I have a little drip drip drip and my water pump cycles on constantly. It is just the faucet (cheap o plastic thing). So, I will turn off the water and either just get a replacement gasket or maybe even replace the faucet since I have been wanting a taller neck. My question is: Do I turn off the water under the couch? There is a shut off valve between the freshwater tank and the water pump. Or do I need to shut off downline of the pump? Also, that valve seems VERY stiff. Do we think it is just overtightened? Should I force it? Thank you all! Just a solo camping girl here trying to figure it out on my own. You all have always been so helpful. I appreciate you! Quote
linda s Posted April 3, 2025 Posted April 3, 2025 Just turn off your pump. Replacing the faucet is the best way to go. Just have a towel under there to catch the little bit of water that will come out. I never leave my pump on. I just turn it on when I need water. Old pipes and fittings, a water disaster could happen at any time. Linda S Quote
