Ctgriffi Posted February 16, 2025 Posted February 16, 2025 I’m searching high/low for the correct extinguisher that fits in the slightly-recessed factory mount of my 91 Warrior. The cylinder needs to be 2-7/8” diameter and approximately 12-15” in overall height. The width measurement is the important number, for it to sit securely and use the provided clasp. Anybody found a recent extinguisher that fits well? Quote
Ctgriffi Posted February 22, 2025 Author Posted February 22, 2025 Found a good solution, thanks to 3D printing: I bought the closest-sized extinguisher that I could find (similar to the old 90s version, but significantly wider cylinder) and then designed a new strap to fit it perfectly, printing it in TPU (flexible, rubbery substance). The strap is fairly simple but, like usual, I had to test-and-tweak several versions to get a nice, snug fit—yet something that opens and releases easily when needed. Here are some photos of the new strap and how it works with the new extinguisher and the factory-provided recessed mount: Quote
