Ctgriffi Posted February 7 Posted February 7 (edited) I've been thinking hard lately about pulling the original Norcold 875EG2 out of my rig, replacing with a good mini fridge. The Norcold generally works but is WAY old, hard on the eyes, and BAD at maintaining a consistent temperature across day/night. Also, I already have an (efficient) inverter setup to supply the 110v for a standard mini fridge, and we just never use the existing unit on propane (moot point, for us). Couple thoughts and questions: Anybody done this recently and have thoughts/suggestions/regrets? The Norcold has about 4.5 cu.ft. capacity, is "built in" and fits snugly into the surrounding cabinetry, and is roughly 40" H x 23" W x 20" D. I haven't found anything that matches those ^ dimensions closely, especially in height since most are between 30-33" tall. So I either need to "wall-in" the additional space, or create some kind of cubbyhole storage area, below or above. Any opinions on this? Biggest Concern: should the original fridge outdoor access panel and roof vent be sealed and insulated... or left as-is? Edited February 7 by Ctgriffi Quote
extech Posted February 7 Posted February 7 that fridge makes cold by removing heat. it needs somewhere to go. depending on where it comes out will be the deciding factor for where the vent needs to be. Quote
IdahoDoug Posted February 8 Posted February 8 Agree with Extech. The new fridge has to have a lower vent (intake) and an upper vent (exhaust) to allow the heat to escape the camper. Your current fridge essentially has a sealed off area at the rear for this heat and air flow that prevents heat from entering the camper. So your new fridge with different dimensions will simply need some new wood or another material to also seal it off. For instance, I am installing the largest fridge that I can physically get into my Sunrader, and I will have to do the same thing. I opted to reuse the original fiberglas drip pan under it, by making it wider - you'll have to figure something out as well. Best. Quote
