Aussie Ray Posted January 9, 2025 Posted January 9, 2025 (edited) Gidday Planning on restoring water damaged walls Any tips Edited January 9, 2025 by Aussie Ray Update Quote
83 dolphin Posted January 9, 2025 Posted January 9, 2025 Be ready to find more than you bargain for. We thought we had two walls that needed love after buying one to fix up and today as I type this we are replacing the roof after a floorboard up repair! we replaced most with 1x2s, and attached in a pocket hole fashion Quote
linda s Posted January 10, 2025 Posted January 10, 2025 Truth is because none of us have any experience with the type and make of motorhome you have, Australian right-hand drive, we can't really give you an exact answer. For just water stains I have had very good results with some spackle to smooth it out and good quality semi-gloss paint. For major damage that would require replacement, the framework is important. If it's made out of wood that might need replacement too, If the structure is in good condition, you might be able to remove the damaged panels and put in new wall board or paneling. Most of these rigs have a pattern on the walls so painting throughout is probably required to make everything match. Look for the closest texture to your existing wall. Good luck Linda S Quote
Aussie Ray Posted January 11, 2025 Author Posted January 11, 2025 Thanks for that I have ripped the panelling off and it is quite wet Looks like a major job Structure timber are wet and quite rotted Hope to repair from the inside without removing outside walls Thanks Quote
Aussie Ray Posted January 11, 2025 Author Posted January 11, 2025 83 Dolphin What type of 2x1 did you use Hardwood or softwood and use a pocket drill? Oregon or pine ? Quote
