clifton maggard Posted January 1, 2025 Posted January 1, 2025 These forums have been very helpful. I have a 1980 Toyota Dolphin RV series 500 . In the area where they have the electrical it has a 30 amp breaker and a 15 breaker. Does this make sense, for the wire that's connected to the air conditioner is a 12/3, thus 20AMP Max wire. Shouldn't that be a 20 amp breaker. Also what should the shore power be 120 volts 20 amp or 120 volts 15 amp STOCK. Trying to set it up like it was stock from the factory. Also does anyone have an electrical diagram, for it has been modified horribly. Thanks CMaggard Quote
WME Posted January 1, 2025 Posted January 1, 2025 See if you can find the sticker for the A/C. Normally the 15 amp powers everything in the RV, except the A/C. My current rig has two 20 amp breakers, one for for each A/C A little foggy memory but I seem to remember a 3rd breaker in my Toy (10-15 Amp) for the microwave Quote
clifton maggard Posted January 1, 2025 Author Posted January 1, 2025 Thank you. I did find that sticker, but it was too faded read. I did find this 1979 Dolphin Owners manual below, which might be similar. 1979 Dolphin Owners Manual.pdf Quote
fred heath Posted January 1, 2025 Posted January 1, 2025 Does you A/C also have a heat function? Quote
clifton maggard Posted January 2, 2025 Author Posted January 2, 2025 Yes. FyI this is not my vehicle it is my sons. From the information from this WebSite we have also determined that my son needed to have dually axle installed, which has been done. Thanks Quote
WME Posted January 3, 2025 Posted January 3, 2025 That diagram looks like its for a fridge, not A/C Quote
extech Posted January 3, 2025 Posted January 3, 2025 ac/heater for sure,although prob not available in 1980 Quote
clifton maggard Posted January 3, 2025 Author Posted January 3, 2025 16 hours ago, WME said: That diagram looks like its for a fridge, not A/C I know very weird. At first I though this diagram for fridge only too, until I saw the HEATER label. This was located under a access panel on the outside of the motorhome on the backside of the fridge. Quote
clifton maggard Posted January 3, 2025 Author Posted January 3, 2025 15 hours ago, extech said: ac/heater for sure,although prob not available in 1980 Just talked to my son and yes it has a heater. Might not be stock ??? . Thanks Quote
WME Posted January 3, 2025 Posted January 3, 2025 16 minutes ago, clifton maggard said: I know very weird. At first I though this diagram for fridge only too, until I saw the HEATER label. This was located under a access panel on the outside of the motorhome on the backside of the fridge. Fridges have heaters. That's how an absorption fridge works, heat from propane flame or heat from an electric heater The fact that the diagram has 115v AC and 12v DC heaters is what triggered the comment. 12v DC heat would be VERY inefficient in a house heater. Quote
extech Posted January 3, 2025 Posted January 3, 2025 the text that was with the diagram said the heater is only to take the chill off Quote
Ctgriffi Posted January 3, 2025 Posted January 3, 2025 46 minutes ago, extech said: the text that was with the diagram said the heater is only to take the chill off My rig had the same description for the small heater coil on the AC unit... but these rigs are so small that it still keeps my wife and I pretty comfortable down to about 25º outside, if you have a good barrier between coach/cab. Quote
WME Posted January 3, 2025 Posted January 3, 2025 2 hours ago, extech said: found this for dometic ac OK this is a proper diagram for an AC... compressor, fan motor and start caps. You will notice the heater is labeled Heat Package and it shows it plugs in. The heater package was/is optional ($75) for most of the RV A/Cs, they are around 5K btu. Most Toy AC are 13.5 K btu, so 5K btu ain't for much but to keep the chill off. Don't forget the racket the fan makes. Quote
clifton maggard Posted January 3, 2025 Author Posted January 3, 2025 5 hours ago, WME said: Fridges have heaters. That's how an absorption fridge works, heat from propane flame or heat from an electric heater The fact that the diagram has 115v AC and 12v DC heaters is what triggered the comment. Didn't think about that very interesting . I see what your talking about now. I have never owned an RV. I'm working on my son's RV. Thank you very much ! Quote
clifton maggard Posted January 3, 2025 Author Posted January 3, 2025 3 hours ago, WME said: OK this is a proper diagram for an AC... compressor, fan motor and start caps. You will notice the heater is labeled Heat Package and it shows it plugs in. The heater package was/is optional ($75) for most of the RV A/Cs, they are around 5K btu. Most Toy AC are 13.5 K btu, so 5K btu ain't for much but to keep the chill off. Don't forget the racket the fan makes. Good to know, thus about 12amps for 5000BTU @120V. Thanks Quote
