Hi Everyone.
I have a suburban NT-16 furnace in my 1988 Toyota Odyssey. Back in 2019 I was having issues where the fan would start, but the ignition sequence never happens. To resolve it back then I bought a replacement board from ebay like this one: https://www.ebay.com/itm/386313082243?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=n-ju0w2ptyy&sssrc=2047675&ssuid=1-1GOiu-Twm&widget_ver=artemis&media=COPY. It solved the issue for me at the time, but the issue has returned.
I've done some troubleshooting steps including:
-Test the propane supply by replacing the regulator
-Bypass the propane plumbing by connecting the tank/regulator directly to the inlet on the heater
-Test sail switch with continuity tester (good)
-Test resistance over both propane valves (40-45 ohm, good)
-Check for voltage to the control board (good)
-Check for voltage at the propane valves 30+ seconds after fan start (no voltage)
I think this isolates the problem to the board.
Does anyone have experience with these? Are the newer boards unreliable? Should I buy another one or potentially a Dinosaur control board (https://www.dinosaurelectronics.com/UIB_S.htm)? Should I bail on the whole thing and replace the whole furnace (either with another NT-16 or maybe something else???)?
Thanks for being a great group.
Edited by GinjaTurtle
Dinosaur boards are good quality. One nice feature is they will attempt to light the furnace 3 times before shutting down. Rather then once like the factory board.
  • 2 months later...
I had an issue like this before. Bought a new board and took the furnace apart too. If I remember correctly it was the small thermocouple / temp sensor that was causing issues. It was good but the spade connections were dirty / crusty. Cleaned them and no issues.
It would turn on the fan and try and light 3 times but no ignition because of the thermocouple.
